03-04-2014, 05:24 PM
John, Steve, Warren - thanks.
I will first separate the old base (I need probably to take the whole thing off as, as you remember, one side is a bit arching - need to refit it) and try GoJo (which I have a whole tubfull) and Howards as you suggested.
If it works, it works.
If not, come late spring I will be doing the full thing.
I am not worrying too much about the base trim matching perfectly - there is a different lighting on it and the front anyway due to the different light reflection angles.
I need to order Howards.
Where do you guys order it and do I need the darkest posisble or what several shades would you order if you were to do this cabinet? Dark walnut, medium walnut - what else?
