Philco BOL 41-608 Turntable--HELP
Thanks Sean, hope you can firgure it out. This one does have the record cutter head. What I have right now is 2 seperate pieces...one slips on to the motor shaft, the other slips on the platter shaft. Each piece has a metal center, with a keyway to slip on the respective shaft, and a circular rubber piece riveted each. It looks like the 2 rubber pieces were riveted together at one time. Again, this is what I found...Hopefully you can dig in and check the schematic. It is an early model, with Oct. '40 inspection date...Code 122.....hope this helps...Brian
Philco BOL 41-608 Turntable--HELP - by Guest - 07-21-2008, 07:44 PM
[No subject] - by Sean - 07-22-2008, 12:37 PM
[No subject] - by Guest - 07-22-2008, 02:50 PM
[No subject] - by Sean - 07-22-2008, 08:58 PM
[No subject] - by Sean - 07-22-2008, 09:15 PM
[No subject] - by Guest - 07-22-2008, 10:57 PM
