The Fisher 700-T Receiver
Last night, I finished rebuilding the second of the two driver boards, and decided to try the thing out before I move on to the MPX, IF, and control amplifier boards.
I discovered the power switch does not work. So, I temporarily soldered a wire across it.
Something told me I had better use a Variac to bring it up slowly.
It is a good thing I did! At 60 volts the two 0.68 ohm resistors connected to the left channel output transistors began to release the magic smoke. Icon_eek
I removed the power, disconnected everything, and immediately pulled the output transistors for testing.
One of the left channel outputs has a dead short between emitter and collector.
And the two right channel output transistors are not the correct type - someone replaced them with incorrect parts.
This is why I'm glad I bought that transistor tester...and why I will be checking output transistors from now on before proceeding to repair a receiver, so I will have a better idea of what I will be in for.
The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 10:13 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 10:25 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 10:30 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 10:34 AM
RE: The Fisher 700-T Receiver - by Eliot Ness - 03-29-2014, 12:18 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 03:53 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 04:07 PM
RE: The Fisher 700-T Receiver - by Mondial - 03-29-2014, 06:44 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 07:09 PM
RE: The Fisher 700-T Receiver - by Mondial - 03-29-2014, 07:20 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-29-2014, 07:28 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-31-2014, 04:44 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-01-2014, 04:57 PM
RE: The Fisher 700-T Receiver - by PhilcoMike - 04-02-2014, 02:56 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-02-2014, 03:31 PM
RE: The Fisher 700-T Receiver - by PhilcoMike - 04-03-2014, 02:46 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 09:08 AM
RE: The Fisher 700-T Receiver - by Mondial - 04-04-2014, 11:12 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 11:17 AM
RE: The Fisher 700-T Receiver - by Mondial - 04-04-2014, 03:15 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 03:25 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-04-2014, 03:37 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 03:40 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-04-2014, 03:55 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 03:58 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-04-2014, 04:21 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 04:22 PM
RE: The Fisher 700-T Receiver - by codefox1 - 04-04-2014, 04:24 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 04:25 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 06:22 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 06:28 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-04-2014, 07:45 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-04-2014, 09:21 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-05-2014, 08:17 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-05-2014, 10:19 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-06-2014, 06:59 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-06-2014, 08:41 AM
RE: The Fisher 700-T Receiver - by Mondial - 04-06-2014, 06:58 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-07-2014, 10:32 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-07-2014, 10:38 AM
RE: The Fisher 700-T Receiver - by Mondial - 04-07-2014, 11:04 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-07-2014, 11:10 AM
RE: The Fisher 700-T Receiver - by codefox1 - 04-07-2014, 03:02 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-07-2014, 06:12 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-08-2014, 06:09 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-08-2014, 07:08 PM
RE: The Fisher 700-T Receiver - by BrendaAnnD - 04-08-2014, 08:01 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-09-2014, 10:36 AM
RE: The Fisher 700-T Receiver - by Mondial - 04-09-2014, 12:34 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-09-2014, 03:23 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-09-2014, 05:33 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-09-2014, 10:24 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-10-2014, 07:59 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-10-2014, 09:05 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-13-2014, 03:20 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-13-2014, 04:47 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-13-2014, 05:41 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-13-2014, 05:55 PM
RE: The Fisher 700-T Receiver - by Omer - 04-17-2014, 03:07 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-17-2014, 01:17 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-18-2014, 07:14 PM
RE: The Fisher 700-T Receiver - by Omer - 04-19-2014, 12:53 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-19-2014, 01:30 PM
RE: The Fisher 700-T Receiver - by Omer - 04-20-2014, 05:08 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-20-2014, 06:14 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-20-2014, 06:19 PM
RE: The Fisher 700-T Receiver - by Omer - 04-20-2014, 08:15 PM
RE: The Fisher 700-T Receiver - by Mondial - 04-20-2014, 08:38 PM
RE: The Fisher 700-T Receiver - by Omer - 04-23-2014, 11:34 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-24-2014, 08:17 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-24-2014, 08:25 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 04-28-2014, 06:20 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 03:03 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 07:39 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 07:43 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 07:53 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 07:55 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 09:37 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 09:41 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 10:02 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:09 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 10:12 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:25 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:27 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 10:33 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:36 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:39 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-13-2015, 10:43 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:49 PM
RE: The Fisher 700-T Receiver - by morzh - 02-13-2015, 10:56 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-14-2015, 04:37 PM
RE: The Fisher 700-T Receiver - by morzh - 02-14-2015, 05:02 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-14-2015, 06:59 PM
RE: The Fisher 700-T Receiver - by morzh - 02-14-2015, 07:28 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-14-2015, 07:47 PM
RE: The Fisher 700-T Receiver - by Eliot Ness - 02-16-2015, 12:23 AM
RE: The Fisher 700-T Receiver - by morzh - 02-14-2015, 08:36 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-14-2015, 08:57 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-15-2015, 03:56 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-15-2015, 06:04 PM
RE: The Fisher 700-T Receiver - by morzh - 02-15-2015, 06:12 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-15-2015, 07:53 PM
RE: The Fisher 700-T Receiver - by sam - 02-15-2015, 06:16 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-16-2015, 08:00 AM
RE: The Fisher 700-T Receiver - by Eliot Ness - 02-16-2015, 08:29 AM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 02-16-2015, 12:41 PM
RE: The Fisher 700-T Receiver - by morzh - 02-16-2015, 12:58 PM
RE: The Fisher 700-T Receiver - by BrendaAnnD - 02-16-2015, 01:31 PM
RE: The Fisher 700-T Receiver - by morzh - 02-16-2015, 06:07 PM
RE: The Fisher 700-T Receiver - by BrendaAnnD - 02-16-2015, 08:40 PM
RE: The Fisher 700-T Receiver - by morzh - 02-16-2015, 10:10 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-16-2015, 06:33 PM
RE: The Fisher 700-T Receiver - by morzh - 03-16-2015, 07:28 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 03-16-2015, 08:01 PM
RE: The Fisher 700-T Receiver - by morzh - 03-16-2015, 08:47 PM
RE: The Fisher 700-T Receiver - by Ron Ramirez - 10-20-2019, 07:36 AM
