I dont know what to do! Decision made, Restoration begun
According to the GE manual:
LC-759 has Mahogany veneer
LC-759B has Blonde Mahogany veneer.
LC-768 has Walnut veneer.
The picture although in black and white looks pretty dark. If it were me, I'd darken it just a touch to make it look more aged, then apply the gloss.
RE: I dont know what to do! Decision made, Restoration begun - by tom.seeger - 04-03-2014, 08:39 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
