Philco 645 Hum-m-m-m
Yes there is a very pronounced hum, I was using earphones.
Also it does not seem to depend on tuning, it is constant level across the scale.
What Ron said, plus
If the speaker is using a humbucker, is it wired correctly?
And, not sure that applies but just in case : have you seen if the hum depends on the antenna used, on teh position of teh radio relative to the wall, on the loads in your house turned on/off?
Also, do other radio exhibit the same hum or just this one does?
Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 07:21 PM
RE: Philco 645 Hum-m-m-m - by gregb - 04-07-2014, 07:24 PM
RE: Philco 645 Hum-m-m-m - by Warren - 04-07-2014, 08:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 08:23 PM
RE: Philco 645 Hum-m-m-m - by Ron Ramirez - 04-08-2014, 04:31 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-08-2014, 09:10 AM
RE: Philco 645 Hum-m-m-m - by PAradiogeek - 04-08-2014, 10:16 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-08-2014, 12:26 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-08-2014, 11:54 PM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-09-2014, 09:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-09-2014, 12:45 PM
RE: Philco 645 Hum-m-m Fixed? - by Winky Dink - 04-12-2014, 09:43 AM
RE: Philco 645 Hum-m-m-m - by Steve Davis - 04-12-2014, 10:36 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-12-2014, 10:57 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-12-2014, 11:04 AM
RE: Philco 645 Hum-m-m-m - by BrendaAnnD - 04-12-2014, 03:18 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-13-2014, 04:14 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-13-2014, 08:28 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-14-2014, 12:29 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-14-2014, 07:23 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 03:28 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 09:30 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 03:24 PM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-16-2014, 03:43 PM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 04:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-17-2014, 03:54 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-17-2014, 07:54 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-18-2014, 12:08 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-02-2014, 10:20 PM
RE: Philco 645 Hum-m-m-m - by Arran - 07-02-2014, 11:21 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-03-2014, 12:53 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-03-2014, 08:45 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-03-2014, 11:37 PM
RE: Philco 645 Hum-m-m-m - by morzh - 07-05-2014, 10:09 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 12:57 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 07:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 08:30 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 09:16 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-07-2014, 07:04 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
