philco 41-250
howdy! just finishing this up,schematic has ant. term number 1 connected to output tranny.why?external input?
thanks,phil
http://www.nostalgiaair.org/PagesByModel...013407.pdf
philco 41-250 - by philco phan - 07-28-2008, 03:51 PM
[No subject] - by Terry Judkins - 07-28-2008, 06:39 PM
[No subject] - by philco phan - 07-28-2008, 09:27 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
