I dont know what to do! Decision made, Restoration begun
Id love to keep it but my house is being rebuilt and I am in the basement of my parents home with everything I own in the garage. There is just no room for it.
As for the GE phono I don't think the one in it is GE. I have no idea how to connect the phono and the radio is not currently working except for the dial lamps.
I am going to list it on craigslist for a while and see if I can get some money to put towards new radios.
Kirk
RE: I dont know what to do! Decision made, Restoration begun - by OldRestorer - 04-29-2014, 09:08 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3789 online users. [Complete List]
» 3 Member(s) | 3786 Guest(s)
