I dont know what to do! Decision made, Restoration begun
#36
I would put a frequency counter under good to have.
RE: I dont know what to do! Decision made, Restoration begun - by skyscraper - 04-30-2014, 10:59 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5264 online users. [Complete List]
» 1 Member(s) | 5263 Guest(s)
