Radiola 48 chassis restoration
Just to be clear on adding the .22 caps in series to the green wires out of the capacitor/coupling pack. Are you saying just cut the green wires and solder the caps to each side of the wire so that they will be connected to the caps inside the can. Or should I cut the wires and solder the caps to the wire and then solder to the #5 connection on outside of can and the other cap. from the other green wire to the solder tab on outside of can. ? Eliminating the internal caps , but leaving the inductor still in the circuit.
Then the blue wires that come out of the can I see has the .005 cap that goes to the plate of the 45 tubes. So I will cut the blue wires and just put an .005 cap btwn. them. Thanks for the help Arran,John,gregb& jerry.
Radiola 48 chassis restoration - by KCMike - 05-16-2014, 12:52 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-16-2014, 04:10 PM
RE: Radiola 48 chassis restoration - by Mondial - 05-16-2014, 08:01 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-17-2014, 09:38 AM
RE: Radiola 48 chassis restoration - by Mondial - 05-17-2014, 01:38 PM
RE: Radiola 48 chassis restoration - by codefox1 - 05-17-2014, 03:26 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-17-2014, 06:42 PM
RE: Radiola 48 chassis restoration - by Arran - 05-17-2014, 09:56 PM
RE: Radiola 48 chassis restoration - by gregb - 05-17-2014, 10:12 PM
RE: Radiola 48 chassis restoration - by gregb - 05-17-2014, 10:23 PM
RE: Radiola 48 chassis restoration - by Arran - 05-17-2014, 11:04 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 03:11 PM
RE: Radiola 48 chassis restoration - by Mondial - 05-18-2014, 03:41 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 04:53 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 08:04 PM
RE: Radiola 48 chassis restoration - by Arran - 05-18-2014, 08:12 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 08:45 PM
RE: Radiola 48 chassis restoration - by Arran - 05-18-2014, 09:04 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-19-2014, 07:19 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-19-2014, 10:51 AM
RE: Radiola 48 chassis restoration - by Mondial - 05-19-2014, 08:00 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-20-2014, 07:49 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-20-2014, 11:26 AM
RE: Radiola 48 chassis restoration - by Mondial - 05-20-2014, 08:26 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-20-2014, 08:45 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-21-2014, 05:06 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-22-2014, 07:47 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-22-2014, 08:54 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 09:08 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 02:53 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 05:20 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 09:05 PM
RE: Radiola 48 chassis restoration - by Arran - 05-24-2014, 02:42 AM
RE: Radiola 48 chassis restoration - by gregb - 05-24-2014, 09:39 AM
