Philco 645 Hum-m-m-m
#34
One thing leads to another. I was checking some of the caps for leaks, shorts, and grounds; and I noticed that I've placed a 630v cap where the voltage is supposed to be 680v. I've run the set for quite a few hours with no problem. I suspect that the actual voltage is higher than 680v, but my multimeter doesn't go above 600v.
[Image: https://lh4.googleusercontent.com/-lNfXa...520645.jpg]
So I have two questions:
1. Should I replace the cap with one of higher voltage rating? The only solution I have on hand is to use two .2uF/630v caps in series. This is in a two-cap bakelite block, and I can squeeze three caps in if I'm really careful about shorts.
2. To check the actual voltage on the (specified) 680v line, can I put the transformer on 60 VAC from the variac and expect 340 volts?
Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 07:21 PM
RE: Philco 645 Hum-m-m-m - by gregb - 04-07-2014, 07:24 PM
RE: Philco 645 Hum-m-m-m - by Warren - 04-07-2014, 08:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 08:23 PM
RE: Philco 645 Hum-m-m-m - by Ron Ramirez - 04-08-2014, 04:31 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-08-2014, 09:10 AM
RE: Philco 645 Hum-m-m-m - by PAradiogeek - 04-08-2014, 10:16 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-08-2014, 12:26 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-08-2014, 11:54 PM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-09-2014, 09:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-09-2014, 12:45 PM
RE: Philco 645 Hum-m-m Fixed? - by Winky Dink - 04-12-2014, 09:43 AM
RE: Philco 645 Hum-m-m-m - by Steve Davis - 04-12-2014, 10:36 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-12-2014, 10:57 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-12-2014, 11:04 AM
RE: Philco 645 Hum-m-m-m - by BrendaAnnD - 04-12-2014, 03:18 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-13-2014, 04:14 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-13-2014, 08:28 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-14-2014, 12:29 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-14-2014, 07:23 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 03:28 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 09:30 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 03:24 PM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-16-2014, 03:43 PM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 04:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-17-2014, 03:54 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-17-2014, 07:54 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-18-2014, 12:08 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-02-2014, 10:20 PM
RE: Philco 645 Hum-m-m-m - by Arran - 07-02-2014, 11:21 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-03-2014, 12:53 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-03-2014, 08:45 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-03-2014, 11:37 PM
RE: Philco 645 Yet Another Question - by Winky Dink - 07-05-2014, 10:04 PM
RE: Philco 645 Hum-m-m-m - by morzh - 07-05-2014, 10:09 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 12:57 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 07:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 08:30 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 09:16 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-07-2014, 07:04 PM
