Plate voltages for UV-200 tubes
The detector plate voltage should be 22.5 volts but you are close enough it should work. Do you have that detector B+ lead connected to the 22.5 volt terminal on the ARBEIII? If so you should be go.
Gregb
RE: Plate voltages for UV200 tubes - by morzh - 07-27-2014, 09:47 PM
RE: Plate voltages for UV-200 tubes - by gregb - 07-27-2014, 09:59 PM
RE: Plate voltages for UV-200 tubes - by Mondial - 07-27-2014, 10:03 PM
RE: Plate voltages for UV-200 tubes - by gregb - 07-27-2014, 10:23 PM
RE: Plate voltages for UV-200 tubes - by gregb - 07-27-2014, 10:40 PM
RE: Plate voltages for UV-200 tubes - by morzh - 07-29-2014, 09:20 AM
RE: Plate voltages for UV-200 tubes - by morzh - 07-29-2014, 10:09 AM
RE: Plate voltages for UV-200 tubes - by gregb - 07-29-2014, 04:59 PM
RE: Plate voltages for UV-200 tubes - by Mondial - 07-29-2014, 05:31 PM
