Grundig 5005w radio
Now were getting somewhere.
Do you think it needs to be grounded?
I would receive the 1 am station using either the ukw,antenne,or even one of the erde connections.
THere is a loop moounted to the inside of the cabinet which has a plug for the fm band.
Probably nothing on the fm band in 1951?
If that 2 uf e cap is for the fm modulation section, I wonder if I need it?
murf
Grundig 5005w radio - by murf - 08-06-2014, 06:49 PM
RE: Grundig 5005w radio - by Paul Philco322 - 08-06-2014, 07:47 PM
RE: Grundig 5005w radio - by murf - 08-06-2014, 08:23 PM
RE: Grundig 5005w radio - by murf - 08-08-2014, 05:44 AM
RE: Grundig 5005w radio - by Ron Ramirez - 08-10-2014, 06:26 AM
RE: Grundig 5005w radio - by Art Hoch - 08-11-2014, 01:37 PM
RE: Grundig 5005w radio - by murf - 08-11-2014, 09:17 PM
RE: Grundig 5005w radio - by Art Hoch - 08-11-2014, 09:49 PM
RE: Grundig 5005w radio - by Ron Ramirez - 08-12-2014, 05:25 AM
RE: Grundig 5005w radio - by murf - 08-12-2014, 06:35 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4606 online users. [Complete List]
» 2 Member(s) | 4604 Guest(s)
