Display of Philco Radios
I was browsing around the Library of Congress web site and came across this photo,
[Image: https://www.dropbox.com/s/bcmz7j12mdazxb....jpg?raw=1]
You can download a high res image if you like. Not much other info on the photo, just kind of neat.
Display of Philco Radios - by klondike98 - 08-13-2014, 08:25 PM
RE: Display of Philco Radios - by SteveJB - 08-13-2014, 11:49 PM
RE: Display of Philco Radios - by morzh - 08-14-2014, 07:50 AM
RE: Display of Philco Radios - by klondike98 - 08-14-2014, 02:34 PM
RE: Display of Philco Radios - by ccomer1955 - 08-14-2014, 09:20 PM
RE: Display of Philco Radios - by PhilcoJohn - 08-20-2014, 07:13 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
