08-14-2014, 12:58 PM
So far what you said is OK. As long as that Green cap and all it connects to also includes the other (not the green/white) lead of the field coil. If you do get the High voltage there, it does, just confirm it.
Then again, this directly does not affect the filaments' voltage.
What is your input voltage across the primary of the power transformer? I mean, have you measured it?
Last thing: have you done what I asked you to with tubes' pulling? We need to know the FULLY UNLOADED (no tubes in sockets AT ALL) voltage in 80 socket and other (any of the rest) socket with EXACTLY 110VAC measured across the power input.
Last last thing. Is your meter OK? Do you have another one? Does it read a known voltage as it should??
