what are these Philco's?
ok is the bottom one an 118X?
what are these Philco's? - by OldRestorer - 12-09-2014, 10:08 PM
RE: what are these Philco's? - by OldRestorer - 12-09-2014, 10:11 PM
RE: what are these Philco's? - by OldRestorer - 12-09-2014, 10:18 PM
RE: what are these Philco's? - by KCMike - 12-09-2014, 10:31 PM
RE: what are these Philco's? - by tab10672 - 12-09-2014, 11:17 PM
RE: what are these Philco's? - by Ron Ramirez - 12-10-2014, 05:41 AM
RE: what are these Philco's? - by OldRestorer - 12-10-2014, 10:15 AM
RE: what are these Philco's? - by Ron Ramirez - 12-10-2014, 10:56 AM
RE: what are these Philco's? - by OldRestorer - 12-10-2014, 03:41 PM
RE: what are these Philco's? - by AI2V - 12-10-2014, 08:46 PM
RE: what are these Philco's? - by OldRestorer - 12-11-2014, 07:55 AM
RE: what are these Philco's? - by Arran - 12-11-2014, 10:00 PM
RE: what are these Philco's? - by thirtiesradio - 12-12-2014, 02:04 AM
RE: what are these Philco's? - by OldRestorer - 12-12-2014, 09:08 AM
RE: what are these Philco's? - by Arran - 12-12-2014, 11:21 PM
RE: what are these Philco's? - by OldRestorer - 12-19-2014, 08:08 AM
RE: what are these Philco's? - by codefox1 - 12-21-2014, 09:15 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
