12-17-2014, 10:27 PM
Philco flexible resistors are wire-wound on a fiberglas core. Slightly higher heat dissipation and bendable to get into tight places and used as replacements for any radio. Came in 1/3, 1/2, 1, and 2 watt sizes. Marked with standard color code.
If you can fit a modern resistor in it's place (if out of tolerance or bad) with the same wattage rating, then there is no need to replace with a flex part.
Chuck
Chuck
Chuck Schwark,
The Philco Repair Bench
[Image: http://www.philcorepairbench.com/images/philog3tiny.gif]
