01-04-2015, 04:17 PM
Well the underside looks pretty good, although all the paper and electolytic capacitors must be replaced. Topdside, I feel the tuning capacitor will have to be removed, cleaned, lubed, and well if there are trimmers, count turns to tight,k disassemble, clean, reassemble, and bring to original turns, you will be close when you finally realign the set. Should keep you busy 'till spring.
