pioneer sx1500td blowing fuse
#56
What I don't quite get is this:
1. 0.7A at 65V, does it happen with both channels or just one connected? Does not even matter which one? Are you sure.
2. You still know for a fact all your transistors are good?
3. If your Q10 Vbe is almost zero and Q12 Vbe is 34V and your B+ is 65V something should be really smoking. That something would be your R32/R34.
Now, IF both your E2 and E4 are grounded like they should be and B+ is connected, here is your DC path for Q4:
R14 - R20 - D2 - VR4- Q4 C to E - R22. This sets up the DC output.
Now the feedback tht sets it is
R16-VR2-R18.
If you were to remove the output transistors (totally, disconnecting all wires) the VR2 will bring the output (C14plus) to the midpoint of your B+. And the Vc of Q4 should be close to it, maybe a volt or so lower.
If after that you add your power transistors and it gets screwed again, either they are bad or 1/2 Ohm resistors are. Or your C6 or C8 is leaky.
pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 10:59 AM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 12:08 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 02:05 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 02:47 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 03:16 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 03:21 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 04:04 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 04:15 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 04:28 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 05:02 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 05:55 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 06:57 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 08:54 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 09:51 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 10:44 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 11:18 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 07:51 AM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 11:22 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 12:28 PM
RE: pioneer sx1500td blowing fuse - by BrendaAnnD - 11-25-2014, 02:44 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 03:10 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 03:15 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 05:31 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 06:34 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 07:02 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 01:45 PM
RE: pioneer sx1500td blowing fuse - by morzh - 12-15-2014, 02:01 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 02:16 PM
RE: pioneer sx1500td blowing fuse - by morzh - 12-15-2014, 02:22 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 02:35 PM
RE: pioneer sx1500td blowing fuse - by morzh - 12-15-2014, 02:48 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 05:56 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 12:09 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 02:28 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 04:40 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 09:07 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 09:16 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 09:22 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 09:26 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 09:31 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 10:14 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-07-2015, 09:53 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-07-2015, 11:44 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-07-2015, 11:53 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-08-2015, 09:35 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-08-2015, 10:59 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-09-2015, 06:34 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-09-2015, 11:04 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-09-2015, 11:27 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-09-2015, 11:57 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-10-2015, 12:12 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-10-2015, 09:01 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-10-2015, 09:56 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-11-2015, 02:46 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-11-2015, 06:08 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-11-2015, 10:05 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-11-2015, 11:23 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-12-2015, 10:12 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-12-2015, 12:07 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-16-2015, 08:55 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-16-2015, 09:53 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-16-2015, 10:02 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-25-2015, 10:02 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-25-2015, 11:08 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-26-2015, 04:14 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-26-2015, 05:15 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-26-2015, 06:28 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-26-2015, 06:34 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 11:57 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-28-2015, 12:40 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 02:00 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-28-2015, 03:16 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 09:34 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-28-2015, 09:56 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 10:32 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 11:13 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-29-2015, 03:31 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 03:21 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 05:09 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-31-2015, 06:16 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 07:03 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-31-2015, 07:12 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 07:57 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-31-2015, 08:22 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 09:37 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 07:55 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-01-2015, 08:19 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 09:09 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-01-2015, 09:25 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 09:55 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-02-2015, 08:24 PM
RE: pioneer sx1500td blowing fuse - by Eliot Ness - 02-02-2015, 08:36 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-02-2015, 09:33 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-02-2015, 10:41 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-10-2015, 12:57 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-10-2015, 07:14 PM
RE: pioneer sx1500td Fixed! - by KCMike - 04-03-2015, 04:41 PM
RE: pioneer sx1500td blowing fuse - by morzh - 04-03-2015, 05:00 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 04-03-2015, 08:37 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 04-09-2015, 07:56 PM
