pioneer sx1500td blowing fuse
Threads: 69
City: Kansas city, MO.
(01-31-2015, 08:22 PM)morzh Wrote: No, ain't no expert in that.
But before going inside, I would try to (even though I think they are OK) bypass all circuits between MPX unit and control amp by disconnecting everything first from MPX's L/R outputs, and from Con amp IN1 and IN2 inputs and then connecting them respectively L to IN1 and R to IN2.
If it is still low vol, then further exploration into FM circuitry is warranted.
I tried what you suggested. But want to be clear on if I did it correctly.
Unhooked the L & R wires from MPX output pins. Unhooked Con. amp IN 1 & IN 2 wires.
Used jumper wires and connected one to each wire that I had removed from MPX board L/R .Then hooked the other end of each jump wires to each pin( -L to IN 1) & (R to IN2) of Con. amp. I powered up this way on variac and all I got was a hum from the speakers.
I don't know if this is helpful but touching/scratching/tapping, the chassis or the switches with no knobs causes a scraping and or tap sound out of speakers.
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 07:55 PM
Philco 39-116 radio and remote
Hi Brad,
Thanks so much for the info! Do you happen to have the specs for the PT-86 transformer? I did not find a lis...RichG — 04:32 PM |
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran;
If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM |
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM |
Sorry, Chas.
Re the burns, I broke my first TV at the age of 3. Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM |
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM |
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM |
Mr fixr,
That is great news I would love to see repo grille !!
I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM |
Hi Rod,
I always tell people that my scars give me character. :wink: Great job on the radio. Is the grille origi...MrFixr55 — 08:00 AM |
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM |
Hello Chas. Radiomuseum has information on both sets.
Thanks Gary, lots of good info there.
Perhaps we'll ha...ChasL0001 — 02:23 AM |
There are currently 2349 online users. [Complete List] » 3 Member(s) | 2346 Guest(s)
