04-05-2015, 04:42 PM
Thanks. You guys have made your point very nicely. I will hook up speaker and then power up .. I assume I don't need to hookup Phone if I don't select it.
To be on safe side I can hook up thru the dim bulb tester with a 200 watt bulb. the radio states its 125 watts . I read Bulb should be 1.5 to 2 times input wattage. Which would allow the radio to work. Please correct me if that is not true..
Thanks again
Skip...
Thanks again
Skip...
