philco 40-135 Static problem
(04-05-2015, 07:13 PM)David Wrote:  Have you cleaned the tube sockets? Take a real close look at the tuner for dirt or dust balls down deep, I like to use a flashlight and a hand lens. Good luck David
I have cleaned the tube pins knowing that locktals can have a problem with corrosion but you can usually hear the difference when you wiggle each tube with the set on. On the Tuner I have cleaned and checked the plates and at the shaft making sure there is no trash bridging the segments, As a side note I have one of those magnifier visor, best thing I ever bought leaves your hands free!
May have found the problem it is the trimmer on the tuner will run it for a few days to see it that is what it is.
philco 40-135 Static problem - by Eric - 04-05-2015, 09:54 AM
RE: philco 40-135 Static problem - by Radioroslyn - 04-05-2015, 10:28 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 10:37 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 11:22 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 03:45 PM
RE: philco 40-135 Static problem - by Radioroslyn - 04-05-2015, 04:17 PM
RE: philco 40-135 Static problem - by David - 04-05-2015, 07:13 PM
RE: philco 40-135 Static problem - by Eric - 04-06-2015, 08:48 AM
