Restoring a Model 19 Code 126
#71
Measure the resistance from the ANT post to the GND post. If coil is good it will read a few ohms like 10 or less. If bad will read 10K. You know what to do. It"s about the same as the osc coil but not as critical.
Restoring a Model 19 Code 126 - by markmokris - 03-05-2015, 11:18 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 07:55 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 01:41 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 02:03 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 02:59 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-06-2015, 09:38 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 04:54 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-07-2015, 10:19 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 10:23 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-08-2015, 02:37 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-09-2015, 10:16 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-10-2015, 07:16 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 03:01 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 05:25 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 06:25 PM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-11-2015, 06:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 06:53 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 07:45 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 09:06 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 09:24 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-12-2015, 03:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 07:58 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 08:41 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 09:52 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 09:59 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-15-2015, 05:05 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-15-2015, 06:42 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 01:13 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 07:46 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 10:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 10:32 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-21-2015, 04:45 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-21-2015, 06:20 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 08:45 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 08:52 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 08:23 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 08:24 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-24-2015, 08:46 AM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-24-2015, 11:26 AM
RE: Restoring a Model 19 Code 126 - by Mondial - 03-24-2015, 11:57 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 02:08 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 07:44 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-28-2015, 08:00 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-06-2015, 10:31 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-07-2015, 02:34 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-10-2015, 01:19 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-11-2015, 02:53 PM
RE: Restoring a Model 19 Code 126 - by Radioroslyn - 04-11-2015, 03:04 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-14-2015, 08:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-21-2015, 02:49 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 07:25 AM
RE: Restoring a Model 19 Code 126 - by Eliot Ness - 04-24-2015, 09:18 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 10:29 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 12-05-2015, 01:36 PM
