Wire Colors
Ron or Chuck..what color did they use for ground or cathode? Really..brown??The colors you mention seem odd now, but they had to start somewhere. Guess I'm just used to the RMA codes... White as the "hot wire"?? Trouble with that is that white doesn't STAY white. Don't mistake a white wire for brown.. Icon_eek ZZZZZT!! The refined and final RMA code makes more sense--thankfully! Icon_biggrin
Wire Colors - by Robbie Roberts - 12-23-2005, 05:13 PM
[No subject] - by Bill Hutchinson - 12-23-2005, 10:07 PM
Color Code of Philco Wiring - by Chuck Schwark - 12-23-2005, 11:06 PM
[No subject] - by Ron Ramirez - 12-24-2005, 12:10 AM
[No subject] - by Chuck Schwark - 12-24-2005, 09:01 AM
[No subject] - by Guest - 12-24-2005, 02:29 PM
[No subject] - by Bill Hutchinson - 12-24-2005, 05:39 PM
Which RMA code? - by Robbie Roberts - 12-24-2005, 06:10 PM
[No subject] - by Chuck Schwark - 12-24-2005, 09:15 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5257 online users. [Complete List]
» 1 Member(s) | 5256 Guest(s)
