Restored Airline 62-101
Fred....Looking great as always thank you for posting your beautiful radio!
Restored Airline 62-101 - by Fred Taylor - 05-21-2015, 07:54 PM
RE: Restored Airline 62-101 - by morzh - 05-21-2015, 08:11 PM
RE: Restored Airline 62-101 - by sam - 05-21-2015, 09:33 PM
RE: Restored Airline 62-101 - by Steve Davis - 05-21-2015, 09:38 PM
RE: Restored Airline 62-101 - by mikethedruid - 05-21-2015, 10:56 PM
RE: Restored Airline 62-101 - by Crist Rigotti - 05-22-2015, 12:22 AM
RE: Restored Airline 62-101 - by jerryhawthorne - 05-22-2015, 02:46 PM
RE: Restored Airline 62-101 - by Fred Taylor - 05-22-2015, 09:40 PM
RE: Restored Airline 62-101 - by mikethedruid - 05-23-2015, 06:46 PM
RE: Restored Airline 62-101 - by PhilcoJohn - 05-24-2015, 05:21 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3547 online users. [Complete List]
» 2 Member(s) | 3545 Guest(s)
