Grunow 654
(07-04-2015, 10:37 PM)vecher Wrote:  I measured -.5 volts using my Old Military VTVM TS-505.
According to schematic it should be -.2 Volts..
[Image: http://i292.photobucket.com/albums/mm38/...szm6qw.jpg]
These radio were run on 110 Volts AC  I think so with my voltage higher it should be more??  The B+ should be around 250 Volts  I measure about 330 volts.. I have a transformer I use on my 390's to step down the voltage .. I guess I will hook it up to radio to see what I get..
Anyway Radio work great..
Skip...
Skip;
  I think that the discrepancy may be explained by the different readings you get from using a DMM/VTVM verses an old fashioned Volt-Ohm meter which was what they typically used in the 1930s, the types they used loaded down whatever they were trying to measure. Radios from then were designed around a working line voltage of 117 Volts, except for 25 cycle versions which were designed around 115, the only power grids that were a true 110 volts were the DC power grids in some major cities.
Just out of curiousity, have you checked the tubes? One thing that can cause a higher then normal B+ voltage is a weak power output tube, a weak tube conducts less current.
Grunow 654 - by vecher - 06-21-2015, 11:36 PM
RE: Grunow 654 - by Arran - 06-22-2015, 02:13 AM
RE: Grunow 654 - by Radioroslyn - 06-22-2015, 06:03 AM
RE: Grunow 654 - by vecher - 06-22-2015, 05:38 PM
RE: Grunow 654 - by vecher - 06-22-2015, 09:35 PM
RE: Grunow 654 - by Arran - 06-23-2015, 12:26 AM
RE: Grunow 654 - by Warren - 06-22-2015, 10:46 PM
RE: Grunow 654 - by jerryhawthorne - 06-22-2015, 11:17 PM
RE: Grunow 654 - by mikethedruid - 06-22-2015, 11:55 PM
RE: Grunow 654 - by vecher - 06-23-2015, 08:51 AM
RE: Grunow 654 - by vecher - 06-23-2015, 07:18 PM
RE: Grunow 654 - by Arran - 06-23-2015, 11:57 PM
RE: Grunow 654 - by codefox1 - 06-24-2015, 07:17 AM
RE: Grunow 654 - by vecher - 06-24-2015, 02:23 PM
RE: Grunow 654 - by Arran - 06-25-2015, 12:45 AM
RE: Grunow 654 - by jerryhawthorne - 06-24-2015, 02:50 PM
RE: Grunow 654 - by vecher - 06-24-2015, 03:14 PM
RE: Grunow 654 - by vecher - 06-26-2015, 03:57 PM
RE: Grunow 654 - by vecher - 07-04-2015, 03:52 PM
RE: Grunow 654 - by Radioroslyn - 07-04-2015, 04:58 PM
RE: Grunow 654 - by vecher - 07-04-2015, 07:57 PM
RE: Grunow 654 - by vecher - 07-04-2015, 10:37 PM
RE: Grunow 654 - by Arran - 07-05-2015, 01:12 AM
RE: Grunow 654 - by vecher - 07-05-2015, 09:51 PM
RE: Grunow 654 - by Arran - 07-06-2015, 02:06 AM
RE: Grunow 654 - by vecher - 07-06-2015, 09:05 AM
