37-675X Opinions
The 37-675 is a pretty good set and uncommon compared to many other high tube count Philcos.
Terry, If he does not want the 37-675 I know someone who does........  Icon_wink Icon_wink
37-675X Opinions - by SteveG - 07-31-2015, 10:19 PM
RE: 37-675X Opinions - by morzh - 07-31-2015, 10:38 PM
RE: 37-675X Opinions - by SteveG - 07-31-2015, 10:41 PM
RE: 37-675X Opinions - by sdradioman - 07-31-2015, 11:20 PM
RE: 37-675X Opinions - by Ron Ramirez - 08-06-2015, 02:04 PM
RE: 37-675X Opinions - by SteveG - 07-31-2015, 11:44 PM
RE: 37-675X Opinions - by Radioroslyn - 08-01-2015, 05:57 AM
RE: 37-675X Opinions - by SteveG - 08-01-2015, 08:56 AM
RE: 37-675X Opinions - by Radioroslyn - 08-01-2015, 04:26 PM
RE: 37-675X Opinions - by SteveG - 08-01-2015, 04:46 PM
RE: 37-675X Opinions - by TA Forbes - 08-06-2015, 11:50 AM
RE: 37-675X Opinions - by SteveG - 08-06-2015, 12:52 PM
RE: 37-675X Opinions - by w4rtc - 08-06-2015, 01:12 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
