When it rains, it pours...maybe I need help.
It seems to be a Webster "Teletalk" model 105M? Hard to say since it's hand written. Most likely, I'll get it working and have no use for it after. Let me see if I can find a schematic or at least puzzle out what the fourth tube could be. It does have nice scroll-work on the grille. I'll try to post another picture of the inlay (or decal) on the top for you.
Charlie in San Antonio
RE: When it rains, it pours...maybe I need help. - by ccomer1955 - 08-15-2015, 07:40 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
