Philco 90 veneer
I personally have only seen a couple of pictures of 90's with the veneer running from side to side like that one. I just bought one but just like a 70 i have the veneer is in book matched figured sheets about 9" wide from front to back.
Philco 90 veneer - by SteveG - 08-20-2015, 12:30 AM
RE: Philco 90 veneer - by tab10672 - 08-20-2015, 06:58 AM
RE: Philco 90 veneer - by OldRestorer - 08-20-2015, 07:44 AM
RE: Philco 90 veneer - by OldRestorer - 08-20-2015, 07:46 AM
RE: Philco 90 veneer - by SteveG - 08-20-2015, 07:55 AM
RE: Philco 90 veneer - by Ron Ramirez - 08-20-2015, 04:59 PM
RE: Philco 90 veneer - by Steve Davis - 08-20-2015, 05:42 PM
RE: Philco 90 veneer - by SteveG - 08-20-2015, 11:27 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
