610 Recapped No Stations
(09-07-2015, 08:39 PM)dfields69 Wrote:  Hello again....I am need of your combined wisdom again folks...I have a little 610 shouldered tombstone I just recapped. I've done a ton of the block caps so I re-stuffed them correctly. I replaced all of the out of range resistor I could find. I used a 2 watt 20-ohm to replace the out of range 10,000 ohm dog bone resistor in the electrolytic section. Per the schematic I hooked the negative ends of the two replacement electrolytic caps one to the 235 ohm tap and the other to the ground end tap of the part #57 two tap resistor. Parts list lists it as 33-3037. I hooked the negative end of the 16 mfd cap to ground per schematic. The set comes on, it will not receive stations. No tubes overheat. There is a popping noise when turn the tone control from one setting to another. No noise is heard when I  put my finger on the grid cap of the  6A7, 78 or 75. Any suggestions? I am stuck. Thanks for any help you can offer!
Have you checked the IF cans? Verify that their resistance value is close to the schematic. Check all components and wiring in the signal path, starting backwards from the audio output stage.
610 Recapped No Stations - by dfields69 - 09-07-2015, 08:39 PM
RE: 610 Recapped No Stations - by KCMike - 09-07-2015, 09:07 PM
RE: 610 Recapped No Stations - by Olskuul - 09-07-2015, 09:09 PM
RE: 610 Recapped No Stations - by Steve Davis - 09-07-2015, 10:28 PM
RE: 610 Recapped No Stations - by dfields69 - 09-08-2015, 09:43 PM
RE: 610 Recapped No Stations - by jerryhawthorne - 09-08-2015, 10:45 PM
RE: 610 Recapped No Stations - by Steve Davis - 09-08-2015, 11:45 PM
