Rare Philcos?
I would add the 29TX to the list of rare Philcos... only 500 manufactured.
And in looking around the web, it seems like all the 28 & 29 chairsides are pretty uncommon. Sure would like to find a 29CSX!
Had a couple radio collectors stop by today and after the tour of all my radios it was the 509X they were really impressed with. The cabinet work inlays, burled book matched veneers and other details of my 509X are just a stunning and rare set to see made by Smyth cabinet company.
They asked me how I knew to look for one of these for 7 years and was at a loss of words actually. I think I read it was rare and liked its look in the Stein console book. Thanks to Ron again for linking me to this one out of San Francisco.
You're welcome, my friend - glad to help Icon_thumbup
Yes, the 509X is very impressive to see in person. I was privileged to see Bruce's 509X last Fall, the only one I have ever seen. It's really a beautiful radio, and Philco went all out to make it a beautiful and unique radio-phonograph.
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4195 online users. [Complete List]
» 2 Member(s) | 4193 Guest(s)
