Have had this television since I was 12 what model is it?
#46
Anything but a 20 sized tube would require that the mounting harness be 'modified' to accept a larger tube. Not all that simple most of the time. Just my 2 cents. Take care and BE HEALTHY! Gary
Hi Brian. Any updates on your progress? Take care and BE HEALTHY! Gary
Hey Gary thanks for reaching out. Well received my used CRT from the Early television museum about a week ago and getting ready to bring the set out and start working on her. Quite the journey to find and get the CRT but its here and I cannot wait to get going on this!  Long overdue!
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
There are currently 3978 online users. [Complete List]
» 1 Member(s) | 3977 Guest(s)
