Rehabilitating a Cardboard Back
 I recently picked up two Transitone “parts” sets:  Models 46-250 and 49-504.  I chose to restore the model 49 because it had a better cabinet, but the back was a disaster.
[Image: https://lh3.googleusercontent.com/-oP8mP...520020.jpg]
Fortunately, the Model 46 back is the same part number and it wasn‘t is such bad condition.  I had never before tried to restore cardboard, but I thought it would be easier than making a new back.
First I removed the labels, stickers, tape, then scraped off the old adhesives.  The damaged areas--both raised and depressed--were leveled and feathered with 220-grit sandpaper.  Then the entire surface was sprayed with a thick coat of clear acrylic and sanded again to eliminate the fuzziness of the sanded areas.
[Image: https://lh3.googleusercontent.com/-5dUnc...520028.jpg]
To restore the frayed corners, I flowed some epoxy cement into the separated layers at the edges and then clamped them with well-lubricated pieces of acrylic (lubricated so they wouldn’t stick to the epoxy).
[Image: https://lh3.googleusercontent.com/-UP00e...520032.jpg]
I re-sanded the corners, then spray-painted two thick coats of Rustoleum gloss khaki (I would have preferred a satin finish).  Immediately, before the khaki coat dried, I lightly over-sprayed with a different color (Rustoleum nutmeg, because it was handy).  The mixture appears more like cardboard than a single tone.  Finally, I coated it with clear satin acrylic to get the desired finish.
[Image: https://lh3.googleusercontent.com/-CrDOz...520036.jpg]
Some of the defects still show through, but overall it has a good appearance and preserves the original stamped part number.  I’m missing one of the four mounting studs, which I’ll try to reproduce, and I’m working on reproductions of the original labels.
Why did I go to all this trouble for a cheap little radio?   I just don’t know.
You went to all the trouble because it's rewarding to try something like that and have it come out well! It looks great! Well done!
Nice!
I have a few for you to do. Icon_mrgreen
Kirk
Nice job!
Thank you, thank you! It's the adulation by my thousands of fans that make it all worthwhile.
AWESOME work!  Thanks for posting your method w/associated pictures.
Craig R
Better than Retro Tronics!
Nice job, showing other people your handy work who have the same interests as you do gives you more satisfaction in the hobby.
winky dink
looks great Icon_clap Icon_clap
now if some one would do a 38-116 ? Icon_thumbup
(11-29-2015, 06:06 PM)sam Wrote:  winky dink
Here you go Sam, sorry for the slight blur Icon_crazy Or I can sharpen  it to crystal clarity with taking a new photo of the back cover I made for my restored 38-116xx. It was copyed from photos seen on defferent web sites and is pretty close to the factory design. This is only pic I have of the rear cover on this 38-116xx. I can make one for you if you need one.
That's impressive. I'd have never known where to start.
(12-08-2015, 05:26 PM)LET-UT Wrote:  That's impressive.  I'd have never known where to start.
Actually its not the same looking as an original but looks good and serves the same purpose, the radio sounds better with one on it Icon_eek
You’re right--it doesn’t look like the original.  If I find the right material someday, then I’ll probably make a new back.  I hadn’t thought about the effect the back has on the sound.  Other than the safety issues, I actually preferred backless radios because you could see some of inside work.
For this Farnsworth I had no example to follow, so I made a compromise.  Not authentic at all, but it’s safe and you can look at the chassis (if you don’t mount the built-in loop antenna).
[Image: https://lh3.googleusercontent.com/-SMXOq...252035.jpg]
(12-09-2015, 11:30 AM)Winky Dink Wrote:  You’re right--it doesn’t look like the original.  If I find the right material someday, then I’ll probably make a new back.  I hadn’t thought about the effect the back has on the sound.  Other than the safety issues, I actually preferred backless radios because you could see some of inside work.
Pretty cool Icon_clap
Renovated Radios has the little T clips that hod the back on for 75 cents each.
John
Las Vegas, NV USA
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 2590 online users. [Complete List]
» 3 Member(s) | 2587 Guest(s)
