Philco 46-350 restoration
I am in the process of restoring a Philco 46-350 portable radio. There are two wires that are not connected. One is very easy. It is the blue antenna wire. The other one is a little strange. It comes up thru the chassis next to the volume control potentiometer. The wire clearly shows in the Riders schematic. This one has cloth electrical tape around the disconnected end. Does anyone know where this end goes?
Terry Hicks
I just looked at mine I am restoring now.. I do not have a wire coming up there.. Look under and let us know whats its connected to and I can look at mine to see where it goes.. If anywhere..
Skip...
I have this picture from the restoration I did on my 46-350. Unfortunately I don't have access to the radio at the moment but the picture clearly shows a taped off wire just like you have. I just left mine taped off like that if I remember correctly.
[Image: https://dl.dropboxusercontent.com/u/5462...46-350.jpg]
I have restored a 46-350. They all have that wire, I believe it is for aligning the radio. It certainly doesn't need to be connected to anything, my radio works beautifully.
Yep I have 2
1 with and 1 with out wire
Sam
they all have that wire,,,and ,,nobody really knows ,,,were it goes and what it is for,,,,,I ,,don't believe that,,,you just pulling our leg,,,lolololol
Mine doesn't have the wire either..
Skip...
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1974 online users. [Complete List]
» 1 Member(s) | 1973 Guest(s)
