Threads: 24
City: Edmonton AB CA
Has anyone bought chassis labels from this fellow, see link below. His ad says he will make what ever label set you want so I asked him for a set for my model 17B and he emailed back and said he's to busy and can't do it. Seems to be a little false advertising to me.
http://www.ebay.com/itm/Philco-Tube-Radi...xycmBS3icT
Gregb
Threads: 310
City: Kings Park NY
Avoid him..
Stuff is crap and he is not a nice person or a good salesman...
Me
AC: 4 DC: 1
Threads: 24
Your are absolutely correct in that statement!
Gregb
Threads: 212
City: Seattle
State, Province, Country: WA
Chuck Paci (cpaci1 at Verizon dot net) sells photo reproductions of original labels.
I'd also be happy to help make some (for the fun of it) - but these would be reproductions rather than scans.
Just to confirm, this is the radio you have:
Gallery link:
http://www.philcoradio.com/gallery/1933b.htm#f
Assuming that's right, here are examples of labels from the 17B:
Chassis label
The chassis label looks pretty much like this 16B label:
http://philcoradio.com/phorum/showthread.php?tid=13832
Patent label
The patent label is essentially the same as this one, just printed larger:
http://philcoradio.com/phorum/showthread...#pid118218
Tube layout label
Threads: 24
Thanks Nathan, that is the radio! If you would make me a set that would be greatly appreciated. PM me the details.
Gregb
Threads: 22
City: Waxahachie, TX
(12-23-2016, 06:52 PM)OldRestorer Wrote: Avoid him..
Me
Ditto!
Crist
Threads: 212
City: Seattle
Repro labels for the 17B added to the Downloads section:
http://philcoradio.com/phorum/showthread.php?tid=16003
Threads: 26
City: Wilmington
State, Province, Country: NC
(12-25-2016, 07:25 AM)Crist Rigotti Wrote: (12-23-2016, 06:52 PM)OldRestorer Wrote: Avoid him..
Me
Ditto!
DITTO AGAIN
Bob T
Got stung with Crap. He just does not care
Threads: 551
City: Jackson, NJ
Chuck seems to make good labels, plus some other things like tube shields. Can't say anything on the seller in question, but I usually go to the people I know and trust first.
Threads: 337
City: lawrenceville nj
So why not try ones Nathan uploaded
Sam
Threads: 22
Well, I got stung by this guy again. Avoid Vintage Radio Labels.
I need a foil RCA "Golden Throat" Label for my 1946 RCA 621TS TV that I'm restoring. He had one and I bit. Here is what he advertised and what I received. A paper one and notice the ladies face color!
[Image: http://i1060.photobucket.com/albums/t458...ndwnzz.jpg]
I may contact Nathan. He is skilled and does a great job on these things.
Crist
(This post was last modified: 04-01-2017, 03:39 PM by Crist Rigotti.)
Threads: 212
City: Seattle
Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality.
Let me know if I can help. From the examples of that label I've seen online it's a bit of a tricky one to reproduce because it requires a gold background (which is normally OK - that just means printing on gold paper with a color laser printer) but also white lettering. Obviously most printers don't print white (or gold), which makes having both in the same label a bit of a problem. Probably the best you could do with a regular printer would be to print the golden-yellow rather than have it be metallic.
Threads: 551
City: Jackson, NJ
Crist
Do you know the joke about stepping twice on the same rake?
Threads: 22
(04-01-2017, 06:32 PM)morzh Wrote: Crist
Apparently not!
Crist
Threads: 22
(04-01-2017, 06:15 PM)Nathan Slingerland Wrote: Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality.
Nathan,
Got your email. Looking into this label a little deeper. I need a good size dimension to begin with. We'll keep in touch over the next few days.
Crist
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
