Philco Labels
Has anyone bought chassis labels from this fellow, see link below. His ad says he will make what ever label set you want so I asked him for a set for my model 17B and he emailed back and said he's to busy and can't do it. Seems to be a little false advertising to me.
http://www.ebay.com/itm/Philco-Tube-Radi...xycmBS3icT
Gregb
Avoid him..
Stuff is crap and he is not a nice person or a good salesman...
Me
Your are absolutely correct in that statement!
Gregb
Chuck Paci (cpaci1  at  Verizon  dot   net) sells photo reproductions of original labels.
I'd also be happy to help make some (for the fun of it) - but these would be reproductions rather than scans.
Just to confirm, this is the radio you have:
Gallery link:
http://www.philcoradio.com/gallery/1933b.htm#f
Assuming that's right, here are examples of labels from the 17B:
Chassis label
The chassis label looks pretty much like this 16B label:
http://philcoradio.com/phorum/showthread.php?tid=13832
Patent label
The patent label is essentially the same as this one, just printed larger:
http://philcoradio.com/phorum/showthread...#pid118218
Tube layout label
Thanks Nathan, that is the radio! If you would make me a set that would be greatly appreciated. PM me the details.
Gregb
(12-23-2016, 06:52 PM)OldRestorer Wrote:  Avoid him..
Me
Ditto!
Crist
Repro labels for the 17B added to the Downloads section:
http://philcoradio.com/phorum/showthread.php?tid=16003
Me
Ditto!
DITTO AGAIN
Bob T
Got stung with  Crap. He just does not care
Chuck seems to make good labels, plus some other things like tube shields. Can't say anything on the seller in question, but I usually go to the people I know and trust first.
So why not try ones Nathan uploaded
Sam
Well, I got stung by this guy again. Avoid Vintage Radio Labels.
I need a foil RCA "Golden Throat" Label for my 1946 RCA 621TS TV that I'm restoring. He had one and I bit. Here is what he advertised and what I received. A paper one and notice the ladies face color!
[Image: http://i1060.photobucket.com/albums/t458...ndwnzz.jpg]
I may contact Nathan. He is skilled and does a great job on these things.
Crist
Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality. Icon_rolleyes
Let me know if I can help. From the examples of that label I've seen online it's a bit of a tricky one to reproduce because it requires a gold background (which is normally OK - that just means printing on gold paper with a color laser printer) but also white lettering. Obviously most printers don't print white (or gold), which makes having both in the same label a bit of a problem. Probably the best you could do with a regular printer would be to print the golden-yellow rather than have it be metallic.
Crist
Do you know the joke about stepping twice on the same rake? Icon_smile
(04-01-2017, 06:32 PM)morzh Wrote:  Crist
Apparently not!
Crist
(04-01-2017, 06:15 PM)Nathan Slingerland Wrote:  Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality. Icon_rolleyes
Nathan,
Got your email. Looking into this label a little deeper. I need a good size dimension to begin with. We'll keep in touch over the next few days.
Crist
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
