philco 9-0 schematic
okay i am working on a philco 90 and I am looking for the schematic for it. I have the one with the one 47 tube but I have an extra bake lite cap in it the number on it is 4989-j I find the cap on the 490 schematic so can some one direct me to the right drawing
benny
you might try the Philco Resources should find something there.
Riders has it. Go to Nostalgiaair.org.
Don't forget Ron's nicely labeled schematics available in the tech section:
http://philcoradio.com/phorum/showthread.php?tid=16721
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
