Threads: 140
City: Lansdale
State, Province, Country: PA
11-29-2017, 08:41 PM
Ok Here is my latest purchase..
[Image: https://farm5.staticflickr.com/4567/2481...867f_b.jpg]
[Image: https://farm5.staticflickr.com/4576/2481...44c9_b.jpg]
Bottom of chassis really clean..
[Image: https://farm5.staticflickr.com/4580/3865...5239_b.jpg]
OK so now on to some of the problems found..
Bad on off switch.. No big deal
Bad RF coil.. Primary open.. May have a parts set on the way soon to help with this..
Bad Power Transformer.. Open HV Leads.. Well 1/2 of it open. From CTR tap to one end measures around 120 Ohms.. From CTR tap to other Open..
Bad output transformer.. Primary open.. Have a replacement on the way..
The Field coil is good..
The Big resistor under neath is Good..
Osc Coils appears good Have to do a little more checking on it..
More to follow.. Glad I didn't pay a lot for it....
One Question: Did other radios use the same Power Transformer? Just incase the Parts set Transformer is bad....
Skip...
Hey Skip,
That is a model 70, not a 90. I corrected your thread title for you
The power transformer was pretty much limited to Model 70 only. Fortunately, Philco made lots of model 70 sets so it should not be too hard to come up with a power transformer, even if you have to buy a junk chassis to get one. Bonus: a junk chassis might have a good on-off switch.
If you aren't in a hurry, you might very well find a 70 junk chassis next May at Kutztown.
Bad RF coil primary? Rewind it! It isn't that difficult to do.
Threads: 140
City: Lansdale
Quick Question.. Did they use Electrolytic Caps on this? Or not.. Schematic I have shows a + on one side of cap..
Skip...
Threads: 51
Skip;
Yes they did use electrolytic caps, and score +1 for this chassis in that it looks like it still has the original cans in place, the larger paper caps (probably bypass caps) are inside those tin boxes under the chassis. I would investigate whether the power transformer actually is bad by removing it and taking the covers off and examining the leads, you have to take it out anyhow if you need to replace it. It's sort of odd to me that even though the H.V secondary is open on one end that the transformer does not look cooked, as in wax and tar leaking out the bottom. I think it may be educational to see if there is a dead short in the B+ circuitry such as a shorted filter cap or bypass cap.
Threads: 70
City: Linn Creek, MO
I agree with Arran. The Philco 70 power transformers are very robust and seldom fail. It's worth taking a look.
M R Radios C M Tubes
Threads: 140
City: Lansdale
Ok, I took the transformer out and its still open on one end.. Took it apart and could not find the break All wires look firmly attached..
Weird I know I will look at it again just to make sure..
Skip...
Threads: 140
City: Lansdale
Ok, Rechecked the transformer. The one side is still open . Tried to probe the transformer leads as deep as I could go but still no luck..
Good news is a have a good transformer on the way..
Thanks ALL
Skip...
Threads: 140
City: Lansdale
Next Question Since this uses Electrolytic caps can they be replaced with 10UF Caps.Originals are 6 UF
Skip..
Or I have some 4.7 Electrolytic caps Can I add a Non electrolytic cap at 2.2 UF to come up with 6.9UF would that work?
Skip...
Threads: 551
City: Jackson, NJ
I would keep the first #41 closer to original, maybe film cap of 6.8uF. The #43 can be 10uF or even more , doesn't matter much,as long as it is equal or above 6uF.
Try not to use general purpose electrolytics for the first cap.
Threads: 140
City: Lansdale
Ok,, Some more problems..
Volume Control pot..
How do you open? Seems like the outer one is supposed to be 5K but measuring is flaky .. Can it be cleaned?
[Image: https://farm5.staticflickr.com/4690/2750...5b4d_b.jpg]
[Image: https://farm5.staticflickr.com/4736/2750...d222_b.jpg]
Thanks
Skip
Threads: 1
City: Mount Hope, Ontario
Hey Vecher, would you mind sharing with me any documents you have on this model? We have the same and I'm struggling to find anything other than a schematic. Thanks!
Threads: 140
City: Lansdale
(12-29-2017, 10:14 PM)AudreyHepburn Wrote: Hey Vecher, would you mind sharing with me any documents you have on this model? We have the same and I'm struggling to find anything other than a schematic. Thanks!
Sure.. No problem PM me with your email address and I can send you what I have..
Skip..
Threads: 268
Hi AH and welcome,
Wanted to make you aware that there are two different versions of the model 70. Also if it is CA built it would be model 70A (has bigger power transformer and filter caps)
Info can be found here: http://www.nostalgiaair.org/pagesbymodel...013833.pdf
Threads: 79
City: Annapolis, IL
Tim
(This post was last modified: 12-30-2017, 10:39 PM by TV MAN.)
Threads: 140
City: Lansdale
Thanks I will read all.. Thanks for finding them.. I'm sure they will really help..
Skip...
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM |
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
There are currently 4068 online users. [Complete List] » 1 Member(s) | 4067 Guest(s)
