Philco 80jr, Calling it done!
First radio restoration in years.
Over 45 years ago went to the dump with a neighbor, saw a Philco cathedral radio sitting there on a pile of old electronics parts, took it home and with the help of my uncle who worked on radios in the 30's/ 40's, got it up and running.
Recently saw this model 80jr radio on craigslist and thought it would be fun to get back into this hobby, didnt realize what I was getting into LOL!
For this cabinet I used the following Mohawk lacquers:
Heavy Body Sanding Sealer M102-0491
Ultra Classic Toner Medium Brown Walnut M100-0207 for the main cabinet
Ultra Classic Toner Light Walnut/ Colonial Maple M100-0352 for the face inner section
Tamiya Spray Black #TS-14 for the line between the light and medium walnut on the front face.
Tone Finish Clear Semi-Gloss M102-0419 for the final clear finish.
I had read on this forum to use the Ultra Classic Toner Perfect Brown for the main cabinet and Medium Brown Walnut M100-0207 for the front face light section, but I found this was too dark for the front light section. So I sanded it off, and used Ultra Classic Toner Light Walnut/ Colonial Maple M100-0352 for the face inner section, but left the sides that meet the grill cloth Medium Brown Walnut, makes for a nice 3d effect that maches the main cabinet color of Medium Brown Walnut.
Lewis
I like it! Icon_clap
Larry
Looking great!
Icon_clap Icon_clap Icon_clap
Is that the original grill cloth? If not, where did you get it?
I get mine at https://www.richmonddesignsinc.com/
That grill cloth is a good match to that used in the Majestic 90 console and the Westinghouse Columnair.
But we cant be picky now-days. Lot better than somebody's spandex - yes this was common in the 80's.
Thanks guys,
Got the Herringbone grill cloth off of ebay.
https://www.ebay.com/itm/Antique-Radio-S...:rk:2:pf:0
It looks a lot like the original that was on the radio.
Lewis
(11-03-2018, 05:50 PM)Lewiss Wrote:  Thanks guys,
Lewis
That is the same guy that Bob mentioned.
thanks.  My 80 jr. has the original but it is a bit shabby.  That cloth looks to be somewhat close to the original and would brighten up the front of my radio a bit.
Very nice attention to detail!
RCA WV-98c
If this is R22, check the voltage on the wiper (86V). If this is R33, see if the lower pin indeed connected to GND, the ...morzh — 02:29 PM
Philco 38-2 Low Volume
Both sch, the one you showed in the beginning and the one I see on Nostalgia, show 40K for the 2nd audio plate.morzh — 02:25 PM
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
There are currently 1544 online users. [Complete List]
» 2 Member(s) | 1542 Guest(s)
