My first restoration 37-610J
Another thing has just occurred to me after rereading your posts. You say you bought a 37-620 radio. I take it you mean a complete radio, chassis, case, and SPEAKER. On these radios, the field coil of the speaker forms a filter choke for the B voltage power supply to the tubes. If you have, that is good. Also, from the pictures you posted, I don't see the speaker mounting board. Did that come with the case? If so, did it have the original speaker with it? I am not sure if the speaker used in the table radios was the same diameter as the ones used in the consoles, so the smaller table speaker may not fit the original speaker board. That won't be a huge problem if you are getting a speaker with 620 you bought. You can just make a suitable mounting board from 1/4" plywood, and cover it with the appropriate grill cloth.
Thanks so much! I'm a complete tenderfoot when it comes to electronics. I think I have someone here nearby who can put some hands on it and figure out what it needs. Here is what the front looks like now.
Very nice!?
Gregg Icon_thumbup
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
