Mystery AVC issue on 38-9
Threads: 6
City: Severance
State, Province, Country: Co
Hello all. I can use some help on another mystery problem, this time on a Philco 38-9
http://www.nostalgiaair.org/Resources/262/M0013262.htm
This is a customer radio that will drop the volume after about 10 min playing. Low to moderately strong stations drop out completely, while stronger stations are still at a listenable level, although equally diminished.
Measuring the AVC voltage tuned to a moderately strong station, at the junction of resistor 15 and cap 3, I see that the voltage starts at about -5 VDC then slowly rises to about -.5 VDC, where the radio abruptly loses volume. Turn is off and let if cool, for a few minutes and and cycle repeats.
I have replace all Electrolytics (twice), all other caps (including the two micas ) and most resistors including 43
I have swapped tubes multiple times
The power transformer voltages are stable
The voltages on all tubes are within tolerances
I have spent hours and hours on this one. I would appreciate any suggestions where I might look as to the source of the disappearing AVC voltage.
Thanks Steve
Threads: 114
City: Sneedville, TN
You haven't said whether you have replaced the paper condensers, I would start there. I suspect the problem is in #23, or #19a, 19b, or 19c. You also may have a resistor which is changing in value as it heats up, especially #20 or #21. It could also be #28, #31, #34, or #36. First step is to replace ALL the paper condensers if you haven't already. If one is sliding in value as it heats up, it means that ALL of them are not reliable any more. I always replace ALL the paper condensers as well as the electrolytics before I do anything else, even before I turn on a set of this age.
Threads: 70
City: Linn Creek, MO
The AVC voltage is not the problem, it is a response to the problem. Something in the front end or the IF is causing the signal to drop, the AVC is trying to compensate. You might try a can of circuit cooler to locate the problem.
M R Radios C M Tubes
Threads: 6
City: Severance
Yes, all the paper capacitors have been replaced. Steve
Threads: 6
City: Severance
Thanks Steve, I totally agree. I need to find root cause. I'm not familiar with circuit cooler or how it's used. Can you fill me in.
Threads: 20
City: Greenville, TX
Here is a source:
https://www.govets.com/maintenance-repai...VNEALw_wcB
Do not keep it on one component very long. Quick spray is enough.
Threads: 6
City: Severance
Good stuff. Have you ever tried cooling the major components: transformers, variable caps, tubes, etc ?
Threads: 543
City: Jackson, NJ
Canned air (duster) when the can is inverted act as a cooler.
Threads: 6
City: Severance
It was the 6K7G. As you all know, Philco radios, with the heat shield socket in tact it will only allow 6K7Gs. 6K7s or 6k7GTs wont fit, at least not without some encouragement from Mr. vice grips. I had 3, count 'em, 3 6K7G's test ok, but all would result the exact same symptoms in the radio. Out of desperation i ground off the rivets holding the socket and shield and put in a metal 6K7, ..... Bingo.
Thanks to all for the help. There are alot of great ideas here I can use next time. And one thing is for sure, there will always be a next time.
Philco 39-116 radio and remote
Hi Brad,
Thanks so much for the info! Do you happen to have the specs for the PT-86 transformer? I did not find a lis...RichG — 04:32 PM |
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran;
If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM |
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM |
Sorry, Chas.
Re the burns, I broke my first TV at the age of 3. Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM |
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM |
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM |
Mr fixr,
That is great news I would love to see repo grille !!
I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM |
Hi Rod,
I always tell people that my scars give me character. :wink: Great job on the radio. Is the grille origi...MrFixr55 — 08:00 AM |
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM |
Hello Chas. Radiomuseum has information on both sets.
Thanks Gary, lots of good info there.
Perhaps we'll ha...ChasL0001 — 02:23 AM |
There are currently 1975 online users. [Complete List] » 1 Member(s) | 1974 Guest(s)
