Philco Predicta yellow screen
Threads: 1
City: Philadelphia
I recently bought a Philco Predicta that of course doesn't work. The plastic picture tube cover was badly covered with a mold or something on the front and back. I cleaned it off (it took kerosene to get it off) but the plastic is badly yellowed. So if I ever get it working the black and white picture will be black and yellow. I've tried bleach, white vinegar, hydrogen peroxide, baking soda, even fine sanding. Nothing is working. Does anyone know a way to get rid of the yellow?
Threads: 268
It might be that the discoloration is though and though the plastic. Just old age.The shell paint is going to be the answer to get an even color. The screen cover you might be able to use a headlight cleaning kit to reduce the yellowing but all of it gone I kinda doubt it. There is some demand for screen covers for both the 17 and 21" but probably not enough to justify the cost of making new ones. I could use a 17" one.
(This post was last modified: 05-25-2021, 07:26 PM by Radioroslyn.)
Threads: 551
City: Jackson, NJ
I just wonder if someone could make injection-molded or stamped transparent plastic.
Threads: 51
I don't know if you can retrobright Tennite like you can with other plastics. Basically you cover it with a creamed hair bleach, and stick it in a clear plastic bag out in the sun for an afternoon, wash it off, then repeat if necessary. Then you could try a polishing compound like Novus, or one of the 3M products for buffing out car paint.
Threads: 1
City: Philadelphia
Thank you for all your suggestions. I'll give them a try and let you know what happens. Another question...Is it possible the plastic picture tube cover is supposed to be yellow or gold? But then the black and white picture would have a yellow tint to it. I have seen pictures of these TVs and the screen does appear to be yellow or gold on some of them. Even ones that are restored. But then there are pictures of ones that look clear.
Threads: 551
City: Jackson, NJ
I don't think it is supposed to be tinted in any way.
Threads: 146
City: Westland, MI
Remember these TV's were around when almost everyone smoked like chimneys because no one knew the hazards back then. Nicotine is a nasty stain medium.
Take care and BE HEALTHY! Gary
Threads: 411
City: Boston
Gary may be onto it, I once cleaned a Zenith Bakelite set that had lived with smokers, I kept wiping off layers of a yellowish brown stinky stuff. Nicotine.....the case came out very good though protected under the scum.
Threads: 146
City: Westland, MI
Personally, I would try non-abrasive GOJO and very soft cloth wipes and see what happens. GOJO shouldn't react with the plastic, but I would try in a less visible area first, My dos centavos. Take care and BE HEALTHY! Gary
Threads: 42
City: Chicago, IL
The screen is tinted. It's supposed to be that way. The plastic is Tenite and slowly decomposes. Heat and humidity accelerate the process. I use Novus #2 polish on mine periodically.
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
