Philco 37-89b missing osc coil and spkr cone\coil
Hey y'all, new here, but not to radios. I posted this question to a FB antique radio group, but got scant help, but maybe there'll be better luck here. This is for a serious restoration for a client.
At some point someone tried working on this thing, but buggered numerous things. The oscillator coil (32-2120) is missing entirely, so I need to source another one, or find turns\wire gauge data and make my own.
Speaker is missing both the cone and the voice coil. The speaker that was in the cabinet also doesn't match the part number for this radio model. It has a 32-9118, but it should be 36-1225. If anyone's got a source for a new speaker or just cone and voice coil for this (incorrect?) speaker, I'm all ears.
Appreciate it!
Since the original inquiry isn't gaining much traction, does anybody know what the impedance is for the voice coil of the original speaker for this model, or models that use roughly the same speaker? The schematics that I have don't show that specification. Part of me wants to default to 8 ohms, but I want to make sure. At this point I'm likely just to remove the field coil and output transformer leave them in circuit, and find a permanent magnet speaker with the same dimensions and impedance.
On the oscillator coil, is there a similar model that uses a similar coil with known specs? Any ideas there? The resistance readings shown in the schematic indicate that the RF coil has rather close resistance readings, so I may have to unwind the RF coil, which also needs work anyway, and use that to get a ballpark idea on rewinding a new oscillator coil, if I can find a bobbin.
Your speaker is a K-7 and can be found on pg 4 here. https://philcoradio.com/library/index.ph.../speakers/
If it was mine I would send it to Rich over @ Sound Remedy. Does great work and prices are reasonable.
As for the osc coil I don't know of any published specs for the # of turns or inductance. You are probably looking at finding a replacement or doing some trial and error to get something that will work.
you could put an add in the wanted ads for the osc coil and speaker if you don't have it repaired.
The original speaker used was S-16 per the "Philco Speakers" file available here on this website (which Terry also linked to in post #3 above). Remember, the radio being discussed is a 37-89B, not an 89B which is a very different animal.
Anyway, the S-16 speaker has an 1140 ohm field coil, and appears to be the same as the S-7 speaker which would be easier to find since it was used in several models between 1933 and 1938.
Regarding the oscillator coil, you are likely stuck with either finding one from a junk 37-89 or 38-89 set, or using one of those "universal" oscillator coils such as this one from Antique Electronic Supply. The problem is, if you go that route, you will only have an AM radio and your band 2 will be dead.
Winding data was never published by the manufacturer.
37-89 and 38-89 sets come up for sale fairly frequently on the auction site, including just chassis. Be careful and don't pay too much, though. A fair price for a parts chassis for one of these is around $20 to $50. Those who ask $100 or more are living in Fantasyland.
That's kind of what I expected as far as the oscillator coil goes - I figured it might be a shot in the dark for technical info. I was already eyeballing the universal coil on AES. I might suggest to the client that the other band selection be changed to aux in, and get that universal oscillator coil just for AM.
On the speaker, hearing that it has the same specifications as a more common speaker from the same era, really helps. That opens up a lot more options.
I may still put in a want-ad in that section of the forum, though.
Thanks!
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1976 online users. [Complete List]
» 1 Member(s) | 1975 Guest(s)
