Have had this television since I was 12 what model is it?
#46
Anything but a 20 sized tube would require that the mounting harness be 'modified' to accept a larger tube. Not all that simple most of the time. Just my 2 cents. Take care and BE HEALTHY! Gary
Hi Brian. Any updates on your progress? Take care and BE HEALTHY! Gary
Hey Gary thanks for reaching out. Well received my used CRT from the Early television museum about a week ago and getting ready to bring the set out and start working on her. Quite the journey to find and get the CRT but its here and I cannot wait to get going on this!  Long overdue!
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5025 online users. [Complete List]
» 2 Member(s) | 5023 Guest(s)
