Looking for TV console model #
Hi,
First time on the Phorum.
I recently acquired a Philco tv, record player, radio console. I followed all the suggestions on the Philco site as to how to identify the model #.  There is no Philco tag on the cabinet, and no chassis # stamped on any of the components.  The tube layout guide is also gone. I did the best I could with a Sam's Photofact #123 which puts the console # at 51-T1443 PL but it's just barely not right.
The first problem I have is that it's missing a tube. The schematic for the RF-IF tuner shows a 6CB6 tube, but on the chassis there is a 9 pin socket, which means I have the wrong schematic.
So... I'm trying to find the console model # , so I can get the correct schematic,  so I can get the correct tube. The back of the tuner just has RF 35 rubber stamped,  and RUN 6.
I've been searching that #, and no results. I have pics of the console, and found one on the internet that looks like an exact match, but still no mod #. And adding pics here is a little tricky.
Any ideas how to find a mod # with no markings on the unit ?
Chris.
Hi and welcome.
Is the other tube a 12AV7? If so looks like the missing tube is a 6BQ7.
Thanks Terry ,
You are correct. The tube next to it is a 12AV7. Not sure how you onew that, but you have skills !
I appreciate the help.
I ordered one and will try it out.
Chris.
Still looking for that model # or how to find it.
Duplicated post of #3. Deleted second post.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4167 online users. [Complete List]
» 2 Member(s) | 4165 Guest(s)
