Philco 42-380 off push button is broken
So I'm having trouble trying to figure out how to fabricate a new piece of either plastic or what looks like pcb to stick to that little part that broke that moves the switch.
Welcome to the Phorum!
Icon_wave
Never faced that problem, hopefully someone has an idea for you short of getting a donor chassis to replace the entire pushbutton assembly.
It might be easier to rig up a toggle switch or a micro switch. That's how the Germans did it.
Thank you klondike.
I think I might have to take the switch assembly out of the radio and maybe drill or hook a strong piece of either metal wire or plastic because I dont think it's worth changing the on/off switch saying it still works underneath.
Here is my solution:
https://www.antiqueradios.com/forums/vie...6&t=385528
I think that the O.P was looking at how to replace a worn down phenolic piece that actuates the switch, not the switch itself. Given that you would have to take the assembly out to replace it, even to replace it with another assembly, I can't see the harm in making a replacement of the worn part and trying it, I'm curious as to what it looked like, the only 1942 model Philco I have is a 42-327, and the P.B assembly is different in those, I think.
I had looked up the 42-327 and it seems slightly different but if anyone could find/get a photo of how it would look it would be very appreciated.
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1976 online users. [Complete List]
» 1 Member(s) | 1975 Guest(s)
