Philco 3650/650 Tuning Mechanism
Hello, I need to dismantle the tuning mechanism in my 3650 (Canadian). I have removed the dial screen but can't figure out how to remove the shadow screen. The picture shows how far I have gone. Also the band selector has a set screw (red circle) that seems to be fused in place. Tried Liquid Wrench having no luck.
Dan
Perhaps this will help  Dial Drive Rebuilding – Models 116, 640, 643, 645, 650, 651, 655, 660, 665 – Philco Library (philcoradio.com) Some set screws can be tough to remove. A good fitting screwdriver is a must with straight blade not rounded on the corners. You can try holding a hot soldering tip on the offending screw. I'm pretty sure that the part is mostly pot metal so if you want to use a torch be careful not to melt it.
Thanks Terry. The link was just what I needed. I'll give the hot soldering iron a try.
Dan
Just as I thought I am missing the dial pointer shield. Any idea where I can get one. Did not find one at Radio Daze. Mine would have 4 arrows.
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 1974 online users. [Complete List]
» 1 Member(s) | 1973 Guest(s)
