Ford Philco F-1540 Installation Manual
Here is a Ford Philco Installation, Operation, and Service manual provided  for the 1938 Ford Radio Model F-1540.  I was not able to find this on this site so it may be a new addition to the library.   Hope it helps someone needing information on this auto radio.
Bill
Thank you. Yes we can add that into the library section.
Thanks Bill!
Now also hosted here in the documents section of the Library:
https://philcoradio.com/library/index.ph...on-manual/
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 3134 online users. [Complete List]
» 2 Member(s) | 3132 Guest(s)
