Replacing electrolytics
Hello - I have a question in regards to replacing electrolytic capacitors. I am working on a B&K model 1076 television analyst that contains many electrolytic capacitors. They are particularly abundant on the circuit boards surrounding the flying spot scanner. I am looking to replace the capacitors; however, I only have polypropylene capacitors. Is it ok to replace electrolytic capacitors with polypropylene capacitors of the same rating and value?
Cheers!
Usually yes. If size is not an issue.
hello Haydenp,
As morzh "Usually yes. If size is not an issue."
If you have them I would go ahead and use them . lately in some my sets that I plan to keep I have been using them too.
Since this unit was made in the tube era there should be enough room, Panasonic has a nice series of large value film caps, I think they are even fused in case something goes to short. Motor run caps are also an option.
Motor run caps are ideal. Except, they are very expensive.
Hello Arran ,
yes I use the panasonice capacitors !
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
