philco 41-290 toner
i am refinishing a philco 21-290 cabinet and wonder if anyone knows which brand and color of toner in spray cans best matches the origional tone.---------------- thanks
Yes - Mohawk Medium Walnut Tone Finish, or Mohawk Medium Brown Walnut Ultra Classic, overall. Unlike some Philco consoles of that period, this one is a "monotone" (single color).
thanks ron ------------lot of hardwood in this cabinet and it is one of my favorite philco models of the 1940 era along with the 40-190
RCA WV-98c
If this is R22, check the voltage on the wiper (86V). If this is R33, see if the lower pin indeed connected to GND, the ...morzh — 02:29 PM
Philco 38-2 Low Volume
Both sch, the one you showed in the beginning and the one I see on Nostalgia, show 40K for the 2nd audio plate.morzh — 02:25 PM
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
There are currently 1223 online users. [Complete List]
» 3 Member(s) | 1220 Guest(s)
