Threads: 112
City: The Villages
I just got a GE radio with a ballast tube. I've never seen one(or heard of one) and was wondering how to test it.
I did some reading about it but couldn't find a test procedure. Any ideas?
Eric
Lake in the Hills, IL
Threads: 88
City: Tacoma
What's the number of the ballast?
Threads: 112
City: The Villages
It's a BL42B
Eric
Threads: 531
City: Jackson, NJ
Eric
You simply measure resistance between the pins where the resistors inside the tube are connected to.
It is that simple.
Threads: 88
City: Tacoma
These ballasts are available from several sources for about $12. Looking at the schematic, I see that pin 3 to pin 7 should show continuity. Pin 7 to pin 8 is the dial lamp connection. To check both sections check from pin 3 to pin 8, then from pin 8 to pin 7
Threads: 112
City: The Villages
Thanks, B A, I'll check it out.
Eric
Threads: 112
City: The Villages
Well, you were right. No continuity at all. I opened it up just to see what it looked like and found broken wires inside. Has anyone put resistors inside the metal tube instead of replacing it?
Eric
Threads: 112
City: The Villages
B A, where did you see them advertised?
Eric
Threads: 88
City: Tacoma
Threads: 112
City: The Villages
Thank you. It will be ordered tomorrow.
Eric
